Results 1 to 10 of 18
Thread: Td42t turbo oil leaking
    Advanced Jayden's Avatar
    Aug 2017
    Brissy/goldy
    962EED18-4A94-46FD-A5DF-A46F15290623.jpegI have alot of oil leaking from the turbo and unsure why? Factory turbo, Runs on 15psi and has been hi flowed says the previous owner. What do you’se think it could be, any help would be greatly appreciated. I have attatched a photo, not sure if the photo has worked. Cheers.
    No pics bud.
    Aug 2017
    Brissy/goldy
    No pics bud.
    Workin now hay?
  5. The Following User Says Thank You to Jayden For This Useful Post:
    mudski (25th September 2017)
    581 Post(s)
    Clean it all up mate, degrease it all, get it all off, start car and carefully watch for new leak and let us know where coming from.
    Possible seal leak of the turbo, not overly expensive to fix.
    Aug 2017
    Brissy/goldy
    Sweet, will do that as soon as i get a chance, cheers mate
    581 Post(s)
    No oil on the top of turbo around the oil feed?
  9. #7
    581 Post(s)
    How'd you go with this mate?
  10. The Following User Says Thank You to AB For This Useful Post:
    Jayden (26th September 2017)
  11. #8
    Aug 2017
    Brissy/goldy
    Had a good look today and it sorta looks like its coming from the actuator. Not 100% sure.
    Gave it a clean with degreaser, and cleared all the oil. Ran the car and went for a bit of a drive and no oil has shown yet, ill keep an eye on it. Cheers mate.
  12. #9
    581 Post(s)
    Yeah it's hard to tell mate, any news today?
    If your not seeing any noticeable leaks from the oil feed or oil drain then likely a seal gone.
    If it is coming out of your actuator then most likely seal on turbo but let us know any updates.
    Does your oil breather from the rocker cover go back through the intake system?
    Would be interested to see if you have oil on the intake side of turbo. Take off the pipe from airbox to turbo and inspect.
    Could be something else if its coming out of actuator but lets not go there yet!
  13. #10
    Aug 2017
    Brissy/goldy
    Had a look today and looks like its leaking out of the bottom of the pipe from the turbo to the intercooler. May just need a catch can. Ive been meaning to have a look through all the piping for oil and have a look inside the turbo, just havent got around to it yet. And yeah the oil breather runs into the intake pipe.
