22nd September 2017, 05:05 PM
SAAS gauges and Narva add a circuit
Hi All,
the progress on my patrol is slow - i am just adding the gauges ready for the Dawes valve. i have bought SAAS tax gauges 2 in 1 boost and EGT and i am trying to use add a circuit and take the power from the fuse box inside the vehicle.
the question is where do i connect them or am i not going to succeed doing it that way.
from the instruction i need:
Black - Earth - i have used the earth point behind the kick panel (Driverside)
Red - switched positive source - controlled via ignition - i was using the cigarette lighter fuse and adding a circuit there?
White - constant battery source 12v - BATT - elec comp - it is blocked in black on my fuse diagram
yellow wire - dash lighting - ? no idea for this one
Any help is greatly appreciated....
Regards,
AM
22nd September 2017 05:05 PM
26th September 2017, 10:44 AM
From my Auber gauge experience, there is no constant 12v needed, the dash lighting is so you can dim the lights in the gauges--needed for power and control of intensity. Good luck!!
26th September 2017, 03:08 PM
Thanks Dr Gary.. got them working i will attach the yellow wire to the pink on the dimmer and all good. Dawes valve next!!
