25th September 2017, 10:05 AM
TD42 Blowby Question.
Hello Everyone,
I have a 89 TD42 with about 370,000km Turbo'd about 30,000km ago and i have noticed that its blowby is more noticable. Is there an acceptable amount? considering it was an N/A or should i get new piston rings? Ive ordered a compression kit to check compression which will give me a better idea. whats a normal compression range for the cylinders?
I found a video on Youtube that shows you guys a better idea of what i'm dealing with. I know that says its a "normal" amount, but i'm wanting more opinions.
https://www.youtube.com/watch?v=dhUjFyZMjFE
Thanks.
25th September 2017 10:05 AM
25th September 2017, 05:41 PM
Administrator
I think the Nissan specs are min 355psi to 420psi ish but you don't want a high difference between cylinders. Can't remember the exact percentage but very keen to see your results.
At this stage I wouldn't stress too much until you get the test done.
