Results 1 to 3 of 3
Thread: SAAS gauges and Narva add a circuit
    Apr 2017
    Thornlands
    Hi All,
    the progress on my patrol is slow - i am just adding the gauges ready for the Dawes valve. i have bought SAAS tax gauges 2 in 1 boost and EGT and i am trying to use add a circuit and take the power from the fuse box inside the vehicle.
    the question is where do i connect them or am i not going to succeed doing it that way.
    from the instruction i need:
    Black - Earth - i have used the earth point behind the kick panel (Driverside)
    Red - switched positive source - controlled via ignition - i was using the cigarette lighter fuse and adding a circuit there?
    White - constant battery source 12v - BATT - elec comp - it is blocked in black on my fuse diagram
    yellow wire - dash lighting - ? no idea for this one
    Any help is greatly appreciated....
    Regards,
    AM
    Gold Coast
    From my Auber gauge experience, there is no constant 12v needed, the dash lighting is so you can dim the lights in the gauges--needed for power and control of intensity. Good luck!!
    Apr 2017
    Thornlands
    Thanks Dr Gary.. got them working i will attach the yellow wire to the pink on the dimmer and all good. Dawes valve next!!
