Results 1 to 8 of 8
Thread: Glow plug relay and inline fuse
    Sep 2017
    Nowra
    Hey guys I couldn't seem to find information about what size relay and inline fuse to use when wiring up glow plugs to a momentary push button ..? I have a 40amp relay and 30 amp fuse.. is that going to be okay when hooked up? Or do I need something bigger?
    Brodie
    192 Post(s)
    Hey mate, pretty sure mine is running a 30 amp fuse, never been a problem. .
    Sep 2017
    Nowra
    Cool, what size relay have you got? Mine is 40amp.. will that be okay to run glow plugs or?
    192 Post(s)
    Hmmm don't know, it's the factory one.
    192 Post(s)
    Appologies, just checked, it's got a 60A fuse in it. Big sucker but that makes sense. . .
    Sep 2017
    Nowra
    Okay I'll get a larger fuse then, and I have the factory one but how do I hook it up then if I'm running it off a button and using a tb42e loom? I was going to run it on its own , would I just do the same?
    Also I have a massive bird nest of unused wires in my engine bay , once I have everything up and running, is it safe to cut away all the unused wires to tidy everything up?
  8. #7
    192 Post(s)
    Yeah just run it on it's own should be pretty simple. Just 12v in, output to plugs and signal wire. I did have manual push button glow in mine but recently put in a bogarrt aftermarket timer which works really great too. . . Both do the job tho, timer is just s bit more of a factory finish and convince really.
    Yeah once your sure all the excess wiring isn't needed chop away. Took a fair bit out mine of mine when i did the conversion was quite cleansing really. . .
  9. #8
    Sep 2017
    Nowra
    How do I know what, what pin is on the relay though?
    And yeh hahaha was thinking the same as you! Can't wait to remove all the excess and tidy it up 😁
