Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 46
Thread: Help wiring Tb42e loom into td42t
  1. #31
    Sep 2017
    Nowra
    Would the neutral safety switch be the issue? I've gone from Tb42e auto to td42 manual using the Tb42e auto loom...
    193 Post(s)
    Quote Originally Posted by BrodieTiGQ View Post
    Got reds but no radio or anything ?
    What's reds? Have you checked all the fusable links are hooked up & all good, Ignition switch is hooked up right.? Not sure about auto neutral cut out. . Possibly, need someone but more learned than me with electrics but wouldn't stop the accessories from working tho. . .
  4. #33
    Sep 2017
    Nowra
    Can you send a picture of your wiring? And engine bay?
  5. #34
    Sep 2017
    Nowra
    Fusable links..? What's a fusable link?
  6. #35
    Sep 2017
    Nowra
    Where's the ignition switch? Cause i thought that too.. cause the starters not even cranking..
  7. #36
    193 Post(s)
    Fusable links come straight off the battery and go to certain parts of the loom. Theres one that goes to the igniting switch (key barrel), sounds like that one might not be hooked up maybe. They're the ones on the left of the battery with white & black plugs.
  8. #37
    Sep 2017
    Nowra
    I don't have plugs like on mine?
  9. #38
    193 Post(s)
    They all sit in a black plastic bracket type thing on the GQs. Kinda hard to see it in pic but next to orange winch wiring. Yours should have something similar . .
  10. #39
    Sep 2017
    Nowra
    Yeh it did I took them all out , but I don't have them wires in the picture? Could you get a closer picture tomorrow?
  11. #40
    193 Post(s)
    Hard to get a good picture with all the crap in the way. First ones looking from the back, in the second one should have something that hooks up to the battery like the green & orange plug & black plug. If there not there that'l be your problem i recon. .
