Results 1 to 10 of 12
Thread: Caster correction Bushes on a 2 inch lift
    Jun 2015
    Perth Tapping
    Hi All,
    Looking at doing a 2 inch lift on my 2007 patrol wagon, Many people saying you don't need to fit bushes and some say you do ?? What do you guys think who have a 2 inch lift ?? prob going with Raw or iron man lift as not got lots of $$$ prob looking at $1390 springs nitro gas shocks caster correction bushes and steering damper fitted or I could do my self and no damper or bush just springs and shocks for $735 that is ironman.
    what do you think thanks Dave
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by madchef View Post
    Hi All,
    Hi Dave - had mine done at West Coast Suspension for about $1200 two years ago. No fus or bother and they have been around awhile doing mining trucks etc. That included a new steering damer. No new bushes or steering alignment required for 2". I replaced the drop links at a later date and don't forget to extend the brake bracket at the rear. Can't remeber the name of it but it equalises the front and rear brakes and helps when you are loaded or not. Its attached to the body, so if you go up 2" you need to extend the bracket down 2" to keep the same tension on the spring. If you do it yourself, get a wheel alignment after fitting.
    Cheers Tony
  4. The Following User Says Thank You to 4bye4 For This Useful Post:
    madchef (14th September 2017)
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    +1 on no bushes.
    I got a new damper as well but no bushes needed.
    A wheel alignment after installation finished the job.
    It handles much better than before the lift.
  6. The Following User Says Thank You to Mc4by For This Useful Post:
  7. #4
    Jul 2013
    3 Post(s)
    Same thing happened here when I got a 2 inch lift, but after a few years of owning the GU, the rubbers needed to be replaced due to age and the correction rubbers were put in, but not by choice though. I`m not worried by it being done with the correction, as they needed to be replaced any way. 6 of one and half a dozen of the other. All depends on the condition of them now on your vehicle.
  8. The Following User Says Thank You to Bush Ranger For This Useful Post:
  9. #5
    Jun 2015
    Perth Tapping
    Thanks guys, will leave bush out then, will be getting new tyres also so will get lift then tyres then Aligment think that will do as will cost $$ snorkel. Next on my list.. will give west coat a call.... thanks
  10. #6
    Didn't bother on my first GQ, they were already fitted to my second GQ, didn't notice any difference between the 2
  11. The Following User Says Thank You to Clunk For This Useful Post:
    Bush Ranger (15th September 2017)
  12. #7
    462 Post(s)
    Dont do the bushes, and then when you have done the lift, take it somewhere to get the caster measured. They'll tell you.
    madchef (18th September 2017)
  14. #8
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Agree with mudski as some do need correction bushes some dont. Did mine.
    Madchef, To do yourself you need 4 good stands & a floor jack (need lift chassis up & support it) I have done mine a couple of times, a few tricks involved but you learn as you go and IMO a spring compressor for front coils is handy. Depends on free length of coils, std coils will just fall out. Did my second front coils with the aid of a length of 4x2" timber and you must keep an eye on your brake lines. If new at it you would knock it over in a couple of days by your self.
    IMO Would fit new HD steering Damper. If the veh wanders a little after lift you probably need caster correction bushes.
  15. The Following User Says Thank You to Bidja For This Useful Post:
  16. #9
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    i had to fit castor correction bushes in my gq, but thinking i will get arms when these ones die
  17. The Following User Says Thank You to garett For This Useful Post:
  18. #10
    22 Post(s)
    While this thread is here. Here is something to consider
    As per this picture taken from the Factory Manual, there is only 1 degree of tolerance for castor on a Patrol.
    Seeing that castor correction in pretty much every form is sold as 1 degree for every inch of lift. The possibility of needing some form of correction is quite likely.
    96 GQ coil/Cab
    08 G6eT
  19. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    madchef (18th September 2017), mudski (18th September 2017)
