Results 1 to 8 of 8
Thread: tirfor hand winch
    Advanced da' maverick's Avatar
    Feb 2011
    Sale Victoria
    tirfor hand winch
    g'day.
    i have a tirfor t516 hand winch.
    in need new wire rope for it and im getting stuffed around by people who just have no idea.
    the original wire rope was 11.5mm its a hard to get size. what i have found is ridiculously expensive.
    can i use 11mm or 12mm as these are more common.
    any help would be appreciated.
    worked in tyre industry for 7 years. so any tyre questions just ask
    Expert frenzy's Avatar
    Feb 2011
    Brisbane, QLD
    That would be good to know.
    This website says that the rope has been developed specifically for the tirfor.
    http://www.nobles.com.au/products.aspx?doc_id=2145
    "TIRFOR wire rope The wire rope for the TIRFOR machine is not a standard production rope; it has been developed specifically to suit the TIRFOR machine. TIRFOR wire ropes are supplied on a reeler for ease of transport and storage."
    You've obviously got the T516. Have you tried local 4by shops for a replacement?
    Sep 2011
    adelaide
    18 Post(s)
    G`day da`maverick
    You will have to use the correct size cable as the the collets which grip the cable when you leaver the cable through the machine will not work correctly even if it is half a mill either way, and in a winching situation hang the expence it`s safety first.
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    Try either STENHOUSE LIFTING at Stapylton Qld or ROBERTSONS AND SONS, you can google them and they should be able to send the correct cable to you.
    Tim
    Feb 2011
    Sale Victoria
    thanks guys. i saw the one on ebay. might be the way to go.
    Agree with the above... Tirfor T516 cable has to be 11.5mm. The winch operation relies on the correct cable
    The Ebay cable is a tad dodgy IMHO. It is the correct dia so should be OK but it has an eye swaged on what would be the "feed thru" end. The Tirfor cable needs a clean taper on the feed end so you will have to sort that out if you buy the Ebay cable.
    Get a quote from Nobles or whomever for the genuine article then make a decision from there
  8. #7
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    Hhmmm tirfor... All that spells is really hard work
  9. #8
    Expert TheFlyingBadger's Avatar
    Oct 2010
    Perth
    Seeing as this was dug out for me by Google, I thought i'd update it with what I found...
    $360 for the rope....
    Jon
