8th September 2017, 07:59 PM
5 inch lift
hi very new to 4x4s just wondering what i would need to change to do a 5 inch suspension lift on my 93 gq, i know a little bit like shocks, springs, brake lines but not much else. i plan to put 37s or 40s on it.
8th September 2017 07:59 PM
8th September 2017, 09:55 PM
Smart like tractor
c00kiebr0s
You'll need to change everything basically, including cutting the guards to fit the tyres.
96 GQ coil/Cab
08 G6eT
12th September 2017, 04:36 PM
Ben-e-boy
Can it be legal, so the vehicle doesn't get pulled over and canary papered? Does a lift that high need engineer's cert?
12th September 2017, 05:13 PM
dom14
Can it be legal, so the vehicle doesn't get pulled over and canary papered? Does a life that high need engineer's cert?
It would have to be engineered in WA to be legal. Don't know about other states ro where the OP is. Also 5" will require alingnment and some changes to keep the steering straight and the front wheels in the centre of the guards.
The Following User Says Thank You to 4bye4 For This Useful Post:
dom14 (12th September 2017)
12th September 2017, 07:42 PM
Moderator
It would never get Engineered. With enough guard cutting you will fit 37s under a 2" lifted GQ. Most comp guys run a 2" and 37s without trouble.
Check out my Toy -->
Rogue Dung Beetle
12th September 2017, 07:58 PM
Administrator
MudRunnerTD
Do you know how much they chop to achieve this?
I did 30mm on mine and would love to see how 37's sit, I know it will be tight but possible.
