Results 1 to 6 of 6
Thread: 5 inch lift
    Aug 2017
    5 inch lift
    hi very new to 4x4s just wondering what i would need to change to do a 5 inch suspension lift on my 93 gq, i know a little bit like shocks, springs, brake lines but not much else. i plan to put 37s or 40s on it.
    22 Post(s)
    Quote Originally Posted by c00kiebr0s View Post
    You'll need to change everything basically, including cutting the guards to fit the tyres.
    96 GQ coil/Cab
    08 G6eT
    Legendary dom14's Avatar
    Somewhere inside Victoria, Australia :)
    38 Post(s)
    Can it be legal, so the vehicle doesn't get pulled over and canary papered? Does a lift that high need engineer's cert?
    RB30, some 2-3 inch lift auxiliary LPG tanks
    Few more mods on the way
    http://www.worldwildlife.org/species/tiger
    https://www.panthera.org/
    Cheetah Outreach
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Quote Originally Posted by dom14 View Post
    Can it be legal, so the vehicle doesn't get pulled over and canary papered? Does a life that high need engineer's cert?
    It would have to be engineered in WA to be legal. Don't know about other states ro where the OP is. Also 5" will require alingnment and some changes to keep the steering straight and the front wheels in the centre of the guards.
  6. The Following User Says Thank You to 4bye4 For This Useful Post:
    dom14 (12th September 2017)
  7. #5
    330 Post(s)
    It would never get Engineered. With enough guard cutting you will fit 37s under a 2" lifted GQ. Most comp guys run a 2" and 37s without trouble.
  8. #6
    581 Post(s)
    Do you know how much they chop to achieve this?
    I did 30mm on mine and would love to see how 37's sit, I know it will be tight but possible.
