Results 1 to 10 of 20
Thread: Max tyre 2 inch lift?
    Aug 2018
    What is the max tyre size for a 2000 GU with 2 inch lift? Nothing has been cut etc
    Is it 33s?
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    You will have a tyre placard somewhere that shows max tyre size but on a GQ it's 33" and yes max lift is 2" ,well that's in Victoriastan anyway .
  4. The Following User Says Thank You to GQtdauto For This Useful Post:
    MB (4th September 2018)
    472 Post(s)
    Quote Originally Posted by Drifty3@hotmail.com View Post
    Is it 33s?
    Road legal down here IIRC a max of 75mm increase in our GU heights overall from stock. (tyres & lift together)
    2” great chosen size lift is 50.8mm so only leaves under 1” tyre increase (radius) from your specific tyre placard kindly mentioned by GQTDAuto above. (Placards can model vary too I believe)
    35” ‘moderate’ muddies will scrape a tad experienced out in the bush, most noticeably front end turning hard down a steep descent but nothing to fret too hard over mate!
    EDIT: 35’s not road allowed on GU’s without ‘Portal Axles’ & certified registration thereafter, boys in blue will still query roadside though on sight!
    462 Post(s)
    33's, or a 285/75R16 will fit with ease but you may rub on the front mudflap. To overcome this you either remove the mudflap, or put some radius arm spacers in which push the front wheels forward just enough. 35's will fit but you will again have rubbing issues in the same spot, and its illegal anyway.
    Edit : or as old mate above has said...
  8. #5
    472 Post(s)
    Beat me to the edit same time legalities, good man Mr Mudski Tis a shame, 35’s on a GU could road swerve test up as good as any GQ on 33’s in theory?
  9. #6
    Aug 2018
    So theoretically I could fit 35s? With the 2 inch lift in it
    And keep standards in case the boys in blue nick me?
    Car is very neat not belted up so maybe I could get away with 35s
  10. #7
    194 Post(s)
    35" tyres are not legal, regardless of lift. 33" is the limit. Combined with 2" suspension lift, or 33" tyres only or 3" lift only and no change in tyre diameter.
  11. #8
    472 Post(s)
    As PeeBee mentions above mate and do be extra careful as 3” equates to 76.2mm and they have been known to use metric tapes roadside around here!
  12. #9
    175 Post(s)
    Yeah you'll get away ...
    Till they get you.
    In simplest form of English , 35 inch are a no go. Regardless of how you look at it and how you set your car up.
    462 Post(s)
    Till they get you.
    In simplest form of English , 35 inch are a no go. Regardless of how you look at it and how you set your car up..... unless you spend 20K on Portal axles....
    Ca-ching!!!
