6th September 2017, 09:58 PM
Boost control
Hi all I have a zd30crd and I don't know if I should use a tilix set up or let the ecu control the boost. Do common rails need to be controlled manually?
6th September 2017 09:58 PM
6th September 2017, 10:07 PM
Mick Dagert
Welcome aboard Mick mate! Not too savvy on electrics or ZD's meself but @bigguwesty when he has time may be able to help, good bloke!
Mick Dagert (6th September 2017)
6th September 2017, 10:21 PM
MB
Cheers bud I need all the help I can get
The Following User Says Thank You to Mick Dagert For This Useful Post:
7th September 2017, 05:30 AM
Welcome Mick.
The crd is a lot better than the Di with control.
But is still woeful..
Have you done any of the nads setup yet?
Mick Dagert (7th September 2017)
7th September 2017, 09:37 PM
Thanks bigguwesty.
I've done the exhaust, egr blocked and catch can that's all
7th September 2017, 10:48 PM
Mick Dagert
Thanks bigguwesty.
Hello Mick, 2 weeks ago completed install of NADS on my 2008 CRD and it did include manual boost control (Dawes and needle valve in my case). Re: boost control, l had a few initial issues to overcome of which bigguwesty was a great help. Willing to share my experiences in setting boost operation if you have a need. Very pleased in eng performance now. You may have scan tool to assist in clearing fault codes, I have experienced very few but having a scan tool has certainly been beneficial. My EGR plate is at exhaust manifold. Welcome
The Following User Says Thank You to Bidja For This Useful Post:
Mick Dagert (8th September 2017)
8th September 2017, 05:11 AM
Bidja
Thanks Bidja I do have a scan tool and get the error code a couple of times a week. I wander if a tune deletes that code? But I will purchase a kit where is the best place to look?
8th September 2017, 11:34 AM
Hey Mick.
You'll probably find that with those mods you may have large amounts of over boost.
While curzing I was seeing up to 30 plus psi with those mods on the scangauge..
So yea get onto either a tillix valve or dawes valve. Both do the same thing, I just prefer the design of the tillix that's all.
Mick Dagert (11th September 2017)
8th September 2017, 08:57 PM
Mick, firstly my learning of NADS has come primarily from reading on this forum and the valued one on one advice provided from select members.
Note bigguwesty comment re: either type being contenders and check them out.
Dawes can be acquired from Mudski and he can be contacted via the forum. I installed both the Dawes and needle valve from Mudski and achieved a good result. Certainly would have compared both types if I had knowledge of the 2 options available when I was getting the bits together. Have a read:
http://www.nissanpatrol.com.au/forum...sing-thru-NADS
Understand the EGR block causes the fault code coming up and maybe its placement may also have an effect on their occurrence as well of the driving environments city/rural.
9th September 2017, 07:33 AM
Bidja
Thanks everyone for the help I will order one asap. Where's the best place to buy pillar pods for a boost gauge?
