Results 1 to 5 of 5
Thread: Suspension mount crack
    Dec 2016
    Townsville
    Today I was getting around to getting my rear swaybar links off that I broke a while back. as you can see I did a good job
    However, when I was getting the last one off I found something that looks very unsafe. Seeing as you guys are the experts, what do you reckon? Simple weld job or get another mortgage job?
    iPhone Tapatalk
  2. The Following User Says Thank You to DXsWag For This Useful Post:
    threedogs (4th September 2017)
    461 Post(s)
    Common issue with the wagons. If you have a welder, go nuts. Then get some coil tower braces and fit those up too.
    Hodge (3rd September 2017)
  6. #3
    175 Post(s)
    Yup like mudski said. Weld it and time for some braces !
  7. The Following User Says Thank You to Hodge For This Useful Post:
    Rossco (3rd September 2017)
  8. #4
    192 Post(s)
    Ouch, looks like it's torn the chassis nicely too. Yeah the boss kit is the go. Either weld or get someone else to that's good.
  9. #5
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    That's a pretty big effort.... although apparently common usually not that bad. I'd be getting that fixed (I'm a shocking welder) and definitely check the other side for the same or the start of something.
