Results 1 to 7 of 7
Thread: Clutch?? Sunk patrol
    Expert dpetersen's Avatar
    Jan 2015
    Watarrka National Park
    6 Post(s)
    Hey all!
    Had a bit of a mishap today, got the troll stuck in a rather large puddle. Water was just above the wheels, filled the inside of the car up with muddy water rather quickly. I was stuck for about an hour before I got pulled out.
    Anyway, having a bit of an issue with the clutch I think now. It's going into gear ok but slipping once above roughly 2300 rpm. Only in 3rd, 4th and 5th though. 1st and 2nd seem to be ok. Any ideas?
    2006 4.2 tdi wagon
    TJM BullBar and bar work, Light bar & spotlights, Airtech snorkel, tradie rack, blocked egr, 2inch lift on 33s and a 3 inch exhaust to go with it all.
    Plenty more to come!
    The master farter
    mudski's Avatar
    461 Post(s)
    More than likely the bellhousing has filled up with muddy water. You can take the clutch fork boot off and jam a hose in there and give it a spray. Make sure the water has somewhere to go though. Like somewhere to drain. I did similar years ago, learnt my lesson now and go around bog holes, cost me 2k in the end for damages. Clutch eventually came good, but was never the same. So I changed it out. The pressure plate was cakes with mud.
    581 Post(s)
    Take that little plug out of the bottom of the bell housing and see if anything comes out?
    Feb 2011
    Shed
    45 Post(s)
    You need to take the rubber boot off the clutch fork. With the motor running shove a hose in there and flood with water for a loooooong time until it runs clean. clutch in and out also. Worked for me
  6. #5
    Jan 2015
    6 Post(s)
    Thanks guys.
    So I can see water coming out of where the rubber boot is for the clutch fork so up pull that off. Where abouts is the drain plug for the bell housing?
    2006 4.2 tdi wagon
  7. #6
    Jan 2015
    6 Post(s)
    All good, found it. So far have gotten a heap of water out and it's already a lot better!
    2006 4.2 tdi wagon
  8. #7
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by dpetersen View Post
    Keep going!!
