31st August 2017, 06:37 PM
Administrator
How much wider gu diffs?
Got the green light to save the pennies and work towards getting gu diffs and cvs as my front diff is rooted!
How much wider are the diffs compared to Gq?
Thinking about how much will they come out from the guards as my Flexi flares are bang on with my tyres at the moment.
Not overly keen on getting new crazy wide flares to suit either!
The Following User Says Thank You to AB For This Useful Post:
Winnie (31st August 2017)
31st August 2017 06:37 PM
31st August 2017, 06:54 PM
Nasty Dog - Moderator
Sorry mate cannot answer your question but everything on a GU is better tounge-animated-animation-boy-smiley-emoticon-000343-medium.gif
The Following User Says Thank You to Woof For This Useful Post:
31st August 2017, 06:55 PM
Administrator
Doggy
Oh god, traider!!!!
You used to be cool Doggy
I'm also worried about more scrubbing with the wider diffs too!
31st August 2017, 07:10 PM
Legendary
Pity I threw out a good GQ diff a few years back , just kept the CV's and a few bits and pieces .
Are GU diffs a bit stronger ?
31st August 2017, 07:14 PM
@MudRunnerTD has done this upgrade.
31st August 2017, 07:16 PM
Administrator
GQtdauto
It's mainly the better cvs and brakes from the gu.
GQtdauto (31st August 2017)
The 747
GQtdauto
They are stronger and also have bigger brakes. It's a really good upgrade, on my list to do down the track.
31st August 2017, 07:54 PM
Moderator
The GU CV is significantly bigger and well worth the upgrade. The brakes are a huge bonus.
The length difference is a bit. Been a while but it was abo it a 40mm track change I believe so 20mm side.
Given the track change yo u shou I'd be looking for a pair rather than just a front mate. You will get away with just a front but will suffer a little with rear steer, especially in the Beach Sand.
You will need a new Drag Link and Tie Rod. I recommend a GU Steering Box too.
Check out my Toy -->
Rogue Dung Beetle
The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
AB (31st August 2017), PeeBee (31st August 2017)
31st August 2017, 07:55 PM
Moderator
Obviously a weld on brace kit is a no brainer.
Rogue Dung Beetle
The Following User Says Thank You to MudRunnerTD For This Useful Post:
31st August 2017, 07:57 PM
Moderator
Also swapping your rims over for a lesser offset will sort out the extra track if your really concerned.
Nissan factory rims off a GU will swap straight in and a cheap.
Rogue Dung Beetle
AB (31st August 2017), Rossco (31st August 2017)
