29th August 2017, 08:29 PM
3rd rear row conversion
hi everybody. I have a 2013 y61 gu patrol with the 3rd row of seats being only a 2 seater. I live on the gold coast and I would like to know if there is anybody out there who can do a bench seat conversion on my patrol to make the 3rd row 3 seats?
also, when i click the sub tank button to pump fuel from sub to main tank, will the pump be damaged should i forget to turn off sub tank button if tank completely empties
any help would be greatly appriciated.
cheers,
Steve
29th August 2017 08:29 PM
29th August 2017, 08:47 PM
Legendary
Not sure about the seats but if your changing seating capacity you have a lot of paper work to do , as for the subfuel pump they usually turn themselves off unless something has been altered , then you need to time how long it takes to empty and turn it off manually .
29th August 2017, 08:52 PM
As GQt has said. You will come across legal issues as you are technically adding extra to your GVM. So an engineers report will be needed to do what you require, if you can get a 3 person seat to fit in the back. Which I think you wont. As for the sub tank, it will switch off when then sub tank is empty.
The Following User Says Thank You to mudski For This Useful Post:
GQtdauto (29th August 2017)
