Results 1 to 4 of 4
Thread: Engine stalling once warm
    Feb 2017
    Hey lads and ladettes,
    New the forum so hoping im posting in the correct place,
    i have and issue with my patrol that causes it to stall once it warms up, it a 98 tb45e, Theres no coughing, spluttering or shuddering at all, It drives absolutely perfect apart from this little gremlin, best way i can describe it is, if you were driving along and turn your ignition off, sometimes i don't notice the engine has stopped running until i start to slowdown,
    a mate of mine who is a mechanic at Holden suggested the crank angle sensor may have gotten heat shock but its just a guess as he doesn't know to much about Nissan'ssta
    so i am wondering if anybody has experienced this type of problem and could point in a better direction of fixing it
    any help muchly appreciated
    thanks peeps
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by pachydermatous View Post
    thanks peeps
    Not getting the above bold letter part when comparing it with the original claimed issue of "engine stalling when warmed up".
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Dec 2015
    WA
    5 Post(s)
    I don't know about Nissans, but faulty crank position sensors in Hyundai cars cause this exact fault.
    If you can measure the resistance of the sensor & compare to a known good one or have the specification, the faulty one will most likely be high.
    Graham
    175 Post(s)
    A lot of VS / VT era Ecotec commondoors had issues with the crank angle sensor when hot they stop the motor ....
    I used to poor a bottle of water on the sensor and car would start right up. It was a C*** of a thing.
    Maybe try that first
