Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Running diesel in a petrol engine
    80 Post(s)
    G'day, all. I just watched a video about running a petrol engine on diesel. Would you run a 50/50 mix to get your Patrol out of the scrub or in an emergency?
    https://www.youtube.com/watch?v=PXLWLXz0iY4
  2. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    dom14 (1st October 2017), Softy (7th September 2017)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Only if the alternative was to die. Big difference between a lawnmower motor and a Patrol motor. Life and death maybe because that would justify the new fuel pump and whatever else had suffered.
  5. The Following User Says Thank You to 4bye4 For This Useful Post:
    mudnut (7th September 2017)
  6. #3
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Adding a bit to a tank of fuel stopped the MAV from pinging and running on , was told put 20 cents diesel to one tank of fuel that was a few years ago not sure of how much diesel was but was similar to the additive you put in .
    Running 50-50 mix to get you out of trouble I agree with above life or death possibly only .
  7. The Following User Says Thank You to GQtdauto For This Useful Post:
  8. #4
    80 Post(s)
    Now that would be interesting to test a petrol fuel pump running on a mix for a couple of hours, just to see if it could handle it. The diesel increased the compression a little too.
    After getting home, a complete flush of the fuel tank, change out fuel filters, check and/or change out the spark plugs and an oil and filter change would be on the cards.
  9. #5
    109 Post(s)
    If it was life or death I'd be saying chuck the shit in and lets do what a shepherd does; get the flock out of here! But would have to be life or death scenario or vehicle abandonment scenario.
  10. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    GQtdauto (8th September 2017), mudnut (7th September 2017)
  11. #6
    80 Post(s)
    It is good to know that works, as a last resort.
  12. #7
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    not sure about the mix but have run a petrol car with a substantial amount of diesel. hard to start until its warm but yes it will run. done with both carby and efi. not my first choice but
  13. The Following 2 Users Say Thank You to garett For This Useful Post:
    dom14 (1st October 2017), mudnut (8th September 2017)
  14. #8
    Dec 2015
    WA
    5 Post(s)
    I wouldn't have thought that some diesel in a petrol system would be too bad, add some lubrication, and some smoke.
  15. The Following User Says Thank You to GeeYou8 For This Useful Post:
  16. #9
    80 Post(s)
    Quote Originally Posted by garett View Post
    @garret. How long did you run it, and did you check over the fuel system afterwards?
  17. #10
    192 Post(s)
    I filled up a work car with petrol (diesel car) then drained it and slowly used it as 2 stroke watered if down with more pertrol, you could still see the diesel in it tho but not sure of the mix. Stuff ran but not as good, hard to start and didn't like idleing and HEAPS of white smoke, could smell it too kinda made you sick after a bit . . . Still worked tho, didn't like the idea of throwing fuel away, too tight. haha . . .
  18. The Following User Says Thank You to Rossco For This Useful Post:
