Results 1 to 10 of 17
Thread: Turbo Info
    Aug 2017
    Turbo Info
    Needing info about whether a high flow turbo in my Gu 4.2 Patrol is causing my low down lag and torque issues .Had a dyno tune ,but didnt help.Been advised to replace with standard turbo.Any turbo techs out there can help me find the right path........Thanks
    Beginner MAP8P's Avatar
    Dec 2016
    There are plenty of options out there that out perform standard turbo td05, garrett gtx28 etc. What do you want to achieve?
    Sent from my SM-G900T using Tapatalk
    Aug 2017
    Just want to be able to tow without lag ..turbo is not spooling until 2200 revs after dyno
    Dec 2016
    I currently run a kinugawa billet td05 18g with 8cm turbine housing with 12mm pump boost starts at around 1700 full boost 25psi at 2400 load dependant and holds boost to 4000rpm. Previous turbo was a gt2860 boost response was awesome full boost 18psi at about 1500rpm but ran out of puff about 3000rpm. The Td05 with a 6cm rear housing would probably suit a standard pump better or a gtx28 with a .63 turbine housing.
  6. The Following User Says Thank You to MAP8P For This Useful Post:
    polar Bear (22nd August 2017)
    Aug 2017
    Thanks,sounds a better option the gt2860 ...
    Dec 2016
    Quote Originally Posted by polar Bear View Post
    Sorry hit send before I was finished have edited last post
  9. #7
    North brissy
    Where are you located?
    Where was the "high flow" turbo sourced from?
  10. #8
    Aug 2017
    i am from Hunter valley NSW
    Turbo was already on when i bought it.
  11. #9
    North brissy
    Ok. The stock unit is ok as it is but will not see any gains from modifying it. Which is what you are seeing.
    Which engine combination/ patrol model do you have?
    Do you have any other modifications? Budget?
  12. #10
    Aug 2017
    Its a 4.2 turbo intercooled 2003 model.Three inch exhaust .Just want to get set up for towing mainly.
