Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Anyone recommend a good egt gauge
    May 2017
    Any one recommend a good egt gauge as im getting a new exhaust system next week, already have a saas boost gauge and just wanna hear a few suggestions thanks
    330 Post(s)
    Not SAAS. ... i have a VDO in my GQ and an Autometer in my GUIV and I reckon the VDO is a better unit.
    North brissy
    VDO, auberins, autometer, glo-shift, Mcnally all do nice items.
    472 Post(s)
    Pretty sure Mrs MB's 4.2TD 'Redarc' EGT guage is broken. Keeps beeping and flashing above 550 Degrees when flogging it without an IC :-)
    Are Redarc's even slightly worthy or have we been dudded :-( ?
    GQtdauto (17th August 2017)
  7. #5
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Prefer and currently fitting VDO. Pyro probe and fittings are of good build quality and gauge has a clear plain face. Check the port thread in dump pipe, if one exists as supplied, to be compatible with thread fitting on EGT. VDO has 1/4"NPT(m) fitting but my exhaust dump had two ports (EGT "1/8"BSP & Oxy "18mm x 1.5mm). I decided to use large port and found a reducing bush adaptor SS 18x1.5mm to 1/4" NPT. Secure Fit.
  8. #6
    175 Post(s)
    I have had autron / redarc on both patrols good bit of kit.
    The master farter
    mudski's Avatar
    461 Post(s)
    Running the McNally jobbie in mine. Boost is easy to read on the fly and so is the EGT read out.
  10. #8
    W.A. (wandering aust)
    V d o .
  11. #9
    The master farter
    mudski's Avatar
    461 Post(s)
    Dont flog it Mr MB. Problemo solved.
  12. The Following 2 Users Say Thank You to mudski For This Useful Post:
    GQtdauto (17th August 2017), MB (17th August 2017)
  13. #10
    192 Post(s)
    Another one for vdo nice and simple and easy to read. Redarc usually make nice stuff so assume they're good
