11th October 2017, 08:38 AM
#11
Moderator
smyz250
Finally got to measure up stock and loaded up. Stock the rear wheel arch sits at 915mm from the ground, loaded up (camping gear + tinnie + full tanks and kids in the back) it dropped to 850mm. So a 2.5" sag.
Time to upgrade, 2" lift and +200kg rear should be right
Cheers,
Shane
That should be fine. 400 would be hideous unless your towing a horse float or 6m boat full time.
Consider a set of Polyair air bags that fit inside the coils if your concerned. Spring tower brace for the win too.
Check out my Toy -->
Rogue Dung Beetle
11th October 2017 08:38 AM
16th March 2018, 04:56 PM
#12
Finally got the OME +200kg kit installed today.
Pic below:
So far so good, seems to handle ok and the ride feels fine.
Had a chat about airbags for the rear. Will wait and see how the rake/height at the back settles after a couple of towing trips.
Cheers,
Shane
