Page 1 of 9 123 ... LastLast
Results 1 to 10 of 87
Thread: Tested Gauge Clusters
    80 Post(s)
    Because of the amount of threads about faulty gauges, lately, I am toying with the idea of buying some GQ gauge clusters and testing/repairing and selling them on an exchange basis on the forum, to trusted members. This would not be a full on business but more of a hobby, to start with. If it is successful, I am thinking of also doing the more technically advanced GU clusters. I have been interested in buying a good oscilloscope and signal generator for a long time, and this is a good reason to do so. To get started, I would need some help to get readings such as differing voltage inputs etc. And even average speed sensor readings for different tyre sizes. I would also need opinions on how much members would shell out for a tested cluster. The exchange would only work if everyone promptly returns their cluster and also I need to find replacement parts. Postage to my location may be a prohibitive cost too. This is only a pie in the sky idea at the moment, but let me know what you think. If I cant find original parts, I might have to retro fit after market ones.
    80 Post(s)
    Any interest at all?
    43 Post(s)
    I was wondering if there was a test sequences for them.. Ie x voltage is half tank, or high oil pressure.
    Is there such a thing coz I'd like to test mine to eliminate it from my issues..
    80 Post(s)
    On the early model gauges, most of the input signals can be replicated by a simple voltage and variable resistor and the gauges tested with a multimeter. I want to view, (on an oscilloscope), the average inputs for the tacho and speedos and use a signal generator to produce almost the exact inputs for accurate measurement.
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Most of them are rated at FSD at a certain current. All you would need to do is build yourself a variable constant current source (using a 7805 or such) and then get the gauge specs. Some gauges have the FSD spec written on them.
  7. The Following User Says Thank You to BillsGU For This Useful Post:
    mudnut (27th February 2014)
    80 Post(s)
    I have the guts out of a few different power supplies left over from some other jobs, so it won't be a problem to build one to test Full scale deflection. But I would like to get some wiring looms and make a plug 'n' play unit. And the "Dearest, I need a an oscilloscope and signal generator" factor is at play here too.
  9. #7
    Jul 2010
    Thurgoona
    7 Post(s)
    You won't need much of a signal generator as it would need to be more of a pulse generator. Again a simple kit from Jaycar would do the job. The CRO would also need to be fairly basic as you would not need one with a high frequency response or a large bandwidth. You are mainly looking at pulses at low frequencies.
  10. The Following User Says Thank You to BillsGU For This Useful Post:
  11. #8
    80 Post(s)
    I have done a bit of research and found some basic gear for reasonable prices. Brand new portable LCD oscilloscopes have come a long way since the CRO. I have even found one that has an in built sig gen. I also wish to get back into electronics, which has changed so much since the days of my apprenticeship, in the eighties. I have been shopping around for a small second hand metal lathe as well, so I can have the option of fully reconditioning alternator slip rings.
  12. The Following User Says Thank You to mudnut For This Useful Post:
    Stropp (27th February 2014)
  13. #9
    brisbane
    Drop cuppa a pm incase he has missed this thread as I know his cluster was playing up.
  14. The Following User Says Thank You to megatexture For This Useful Post:
  15. #10
    80 Post(s)
    I'll pm him now, thanks.
