14th August 2017, 06:08 AM
Flex Ramp Build
Hay all,
I'm gonna build a flex ramp to start doing demos at our local car show. Anybody built one before or has designs or pictures of one. Also after any advise on how to do the calculation for you rti score. haven't really goggled it much yet. so any advise would be appreciated.
Cheers fellas
14th August 2017 06:08 AM
14th August 2017, 10:47 AM
Smart like tractor
I think the ramps are about 20 odd degrees.
The maths is
r=d/b×1000
d=distance travelled up the ramp
b=wheel base
At tuff trucks they add wheel track to the formula, but I dont know how or where
96 GQ coil/Cab
08 G6eT
MudRunnerTD (14th August 2017)
18th August 2017, 10:56 AM
yeh cheers. done a bit of research and will be starting the ramp soon.
18th August 2017, 01:31 PM
Are you going to do a bit of Trig (Cosine Rule) using 20 Deg as angle?
Be mindful of your liability using the ramp and that it is deemed to be safe & suitable for its intended use. To cover yourself get a certified ramp or get your design and build certified. I am not an engineer.
