Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: 2003 GU3 4.2 TDI turbo leaking
    Bundaberg
    Morning, My Gu turbo has started leaking around the flanges. I have 260 000 Klm up now . Is is a straight forward job to take off and repair.
    Do you have any idea what would be involved, gaskets etc or is there "O" rings and seals that should be replaced by a Diesel Mechanic.
    Brush.
    May 2016
    8 Post(s)
    mmm first take a look at the inlet pipe is there oil in it ? I t might be a breathing a bit heavy .
    the oil gets separated in the turbo and leaks out .
    The other problem to look for is a blocked oil return line it goes back to the sump .
    other than that its a trip to a Turbo specialist to have a look at . the carterage can be rebuilt carbon seal . but its sometimes cheaper to have a new carterage fitted
    it not a job that can be done with ease . you can bend the shaft just trying to in do it . new seals rebalance bearings its all specialised tools . if set up properly seam to go forever my old Rodeo has 700,000 after a turbo rebuild when it was new still going well .
    Like most things its finding the right people to do it properly . I used to make the tools to do turbo repairs . hope this helps
    330 Post(s)
    Can you post some pics. I would not spend a cent on that turbo if it's at end of life. There is a long list of better. EVERYTHING is better.
    Post some pics and let's see what your looking at.
    North brissy
    If it is factory intercooled it is likely just a build up of oil from the crankcase breather after 260k km. Clean all your piping and intercooler and fit a catch can and monitor.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    MudRunnerTD (10th August 2017)
    Bundaberg
    Thanks for the reply's, I spoke to a DM yesterday as I was not sure of having a go myself. It is the factory setup, he said there were no obvious faults and he would clean it out and renew the metal gaskets.
    We have had this GU for 11 years ,2nd owner it had 167000 on the clock when we got it, they were all hot Klms, cattle buyers vehicle .
    Oil and Filters at 5 and 10000, only replaced Alternator at 130. Clutch at 248. A lot of life left in it yet.
    Cheers Brush
    330 Post(s)
    Quote Originally Posted by brush View Post
    Cheers Brush
    Hi mate,
    i was on my phone the other day but suspected the same as what NissanNewby (NN) stated that it was likely just Crank Case cases that are venting back into your intake. As recommended by NN i would just clean the area and fit a catch can. i.e.. Spray the area with degreaser from supercheap and pressure wash at the car wash then either fit a catch can or at least disconnect the intake vent. (This is the hose that comes out of the round thing at the far end of the rocker cover and the hose goes back into the air intake after the airbag and before the turbo. This sends Oil vapour into the intake of the turbo and would be caught in a catch can. For you it is going into th turbo and now leaking out all over the place. Clean and bypass.
    As i said, leave the Turbo alone. If your Turbo is at End of Life i seriously would come back to these pages and talk about your options as spending Any money on the HT18 Factory Turbo is Madness when is it a Slug and there are sooo many better options for you.
  9. #7
    330 Post(s)
    Cheers Brush
    Also, i have a GUIV with 285k on the TD42Ti. i have owned the car since 98k and always done my own services and Oil / filter changes at 5k to 10k. I still have the original Clutch at 285k, No other major failures. I fitted a New Turbo at 275k with nothing wrong with the HT18 bar performance. In the last 10k running a new Turbo i have never regretted upgrading the Turbo. Its set up for Touring and Towing and it is a Beast. Transformed. I would not spend a cent on the HT18, its better spent towards a better turbo.
  10. #8
    581 Post(s)
    Sorry to slightly hijack your thread Brush...
    My work car GQ Safari turbo is doing exactly the same as above but the breather is not hooked up to intake so would one assume the seal is gone?
  11. #9
    330 Post(s)
    Borg Warner will fix that Mate! You know it. @MB sort that out Mate!!
  12. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    AB (10th August 2017), MB (10th August 2017), Rossco (10th August 2017)
  13. #10
    472 Post(s)
    @AB sort that out mate :-)
