12th August 2017, 12:28 PM
Hardcore
MudRunnerTD
Not really. The snake bite kit is marketed to bush users. Hunters, bush walkers, 4wder. The bandage specifically is for a compression bandage to help achieve optimal compression tension. It is said that it will also help a solo person apply the bandage easily.
Interestingly, this bandage is particularly suitable to Australia. World wide there are a number of treatments for snake bites and not all snakes and spiders have venom that is suitable for a compression bandage. If you get it wrong a compression bandage will be detrimental.
Luckily in Australia ALL Snakes require a compression bandage and ALL Spiders EXCLUDING the Funnel Web and Mouse Spiders all require a compression bandage.
For the benefit of the members.
The treatment for any snake bite in Australia and most spider bites is to identify the bite location before applying the compression bandage.
The snake venom of all Australian snakes does not attack the blood so a tourniquet to the upper limb is a waste of time. The venom travels through the lymphatic fluid so total compression on the limb is essential.
Once the bite site is located take note of its location. DO NOT clean the bite and leave any venom, blood or fluid present on the skin and apply the compression bandage to the entire limb. If available apply a second bandage over the top to the length of the limb. Using a texta or pen clearly Mark on the bandage exactly where the bite site is so that it can be located by medical staff without removing the bandage.
Immobilize the patient and send for help.
When the patient arrives at hospital the medical staff will leave the compression bandage in place and pull aside or cut the bandage only around the bite site and test any fluid to determine the type of venom. It is imperative to treat with the antivenom prior to removing the compression bandage and limit the effect of the lymphatic flow.
This is the same.for spider bites.
Stay safe folks.
I nearly bought the kit but the only thing i'm missing is the SAM splint so thinking I might just buy that separately. I already have their expedition first aid with a couple of the SMART snake bandages
Lucus30's 1999 GU ST TB45E
The Following User Says Thank You to lucus30 For This Useful Post:
PeeBee (12th August 2017)
12th August 2017 12:28 PM
12th August 2017, 02:57 PM
I am he, fear me
MudRunnerTD
Snip...
... Luckily in Australia ALL Snakes require a compression bandage and ALL Spiders EXCLUDING the Funnel Web and Mouse Spiders all require a compression bandage.
Stay safe folks.
Other way around for the Pida's, Cobber... Funnel Web and Mouse Spiders DO require a PIB sama sama as Snake bites.
All other spiders are Ice Pack and monitor IE do not apply a PIB.
http://www.spiders.com.au/spider-bite-first-aid.html
http://stjohn.org.au/assets/uploads/.../FS_spider.pdf
The Following 2 Users Say Thank You to the evil twin For This Useful Post:
MudRunnerTD (13th August 2017), PeeBee (12th August 2017)
13th August 2017, 11:43 AM
Good call on this Doggy, will definitely order one! Now, what to do with the bottle of rum in the first aid kit???
13th August 2017, 03:48 PM
Moderator
the evil twin
Thanks ET. You are right as usual. Ice pack for most bites except Funnel and Mouse Spiders which sh would be treated as per a Snake bite.
Check out my Toy -->
Rogue Dung Beetle
13th August 2017, 03:57 PM
Moderator
the evil twin
Edited the post, thanks mate.
Rogue Dung Beetle
the evil twin (14th August 2017)
22nd August 2017, 03:06 PM
Hardcore
Mine arrived today, looks like a quality kit. Hope to never need to use it.
Jack
The Following User Says Thank You to jack For This Useful Post:
22nd August 2017, 04:33 PM
#17
Moderator
Yeah mine arrived today too with a bonus CPR key fob kit with face shield and valve. Looks like a great lit. Very pleased..
Rogue Dung Beetle
22nd August 2017, 06:20 PM
#18
Yep, so did mine, plus bonus! Good and compact.
#19
Hardcore
Yeap also received the CPR kit and a personalised thank-you note, nice touch.
Jack
19th June 2018, 05:50 PM
#20
Nasty Dog - Moderator
$30 discount on now, just use the discount code TAXTIME at the checkout
https://www.survivalfirstaidkits.net...snake-bite-kit
I have nothing to do with this company or its products, just suggesting that it may be handy to have.
If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
The Following User Says Thank You to Woof For This Useful Post:
