Results 11 to 20 of 23
Thread: Snake Bite First Aid Kit
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Not really. The snake bite kit is marketed to bush users. Hunters, bush walkers, 4wder. The bandage specifically is for a compression bandage to help achieve optimal compression tension. It is said that it will also help a solo person apply the bandage easily.
    Interestingly, this bandage is particularly suitable to Australia. World wide there are a number of treatments for snake bites and not all snakes and spiders have venom that is suitable for a compression bandage. If you get it wrong a compression bandage will be detrimental.
    Luckily in Australia ALL Snakes require a compression bandage and ALL Spiders EXCLUDING the Funnel Web and Mouse Spiders all require a compression bandage.
    For the benefit of the members.
    The treatment for any snake bite in Australia and most spider bites is to identify the bite location before applying the compression bandage.
    The snake venom of all Australian snakes does not attack the blood so a tourniquet to the upper limb is a waste of time. The venom travels through the lymphatic fluid so total compression on the limb is essential.
    Once the bite site is located take note of its location. DO NOT clean the bite and leave any venom, blood or fluid present on the skin and apply the compression bandage to the entire limb. If available apply a second bandage over the top to the length of the limb. Using a texta or pen clearly Mark on the bandage exactly where the bite site is so that it can be located by medical staff without removing the bandage.
    Immobilize the patient and send for help.
    When the patient arrives at hospital the medical staff will leave the compression bandage in place and pull aside or cut the bandage only around the bite site and test any fluid to determine the type of venom. It is imperative to treat with the antivenom prior to removing the compression bandage and limit the effect of the lymphatic flow.
    This is the same.for spider bites.
    Stay safe folks.
    I nearly bought the kit but the only thing i'm missing is the SAM splint so thinking I might just buy that separately. I already have their expedition first aid with a couple of the SMART snake bandages
    Lucus30's 1999 GU ST TB45E
  2. The Following User Says Thank You to lucus30 For This Useful Post:
    PeeBee (12th August 2017)
    Snip...
    ... Luckily in Australia ALL Snakes require a compression bandage and ALL Spiders EXCLUDING the Funnel Web and Mouse Spiders all require a compression bandage.
    Stay safe folks.
    Other way around for the Pida's, Cobber... Funnel Web and Mouse Spiders DO require a PIB sama sama as Snake bites.
    All other spiders are Ice Pack and monitor IE do not apply a PIB.
    http://www.spiders.com.au/spider-bite-first-aid.html
    http://stjohn.org.au/assets/uploads/.../FS_spider.pdf
  5. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    MudRunnerTD (13th August 2017), PeeBee (12th August 2017)
  6. #13
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Good call on this Doggy, will definitely order one! Now, what to do with the bottle of rum in the first aid kit???
  7. #14
    Thanks ET. You are right as usual. Ice pack for most bites except Funnel and Mouse Spiders which sh would be treated as per a Snake bite.
  8. #15
    Edited the post, thanks mate.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    the evil twin (14th August 2017)
  10. #16
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Mine arrived today, looks like a quality kit. Hope to never need to use it.
    Jack
  11. The Following User Says Thank You to jack For This Useful Post:
    Woof (22nd August 2017)
  12. #17
    Yeah mine arrived today too with a bonus CPR key fob kit with face shield and valve. Looks like a great lit. Very pleased..
  13. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  14. #18
    194 Post(s)
    Yep, so did mine, plus bonus! Good and compact.
  15. #19
    Ballarat Area
    25 Post(s)
    Yeap also received the CPR kit and a personalised thank-you note, nice touch.
    Jack
  16. #20
    Perth WA
    61 Post(s)
    $30 discount on now, just use the discount code TAXTIME at the checkout
    https://www.survivalfirstaidkits.net...snake-bite-kit
    I have nothing to do with this company or its products, just suggesting that it may be handy to have.
    If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
  17. The Following User Says Thank You to Woof For This Useful Post:
    Hodge (19th June 2018)
