Results 1 to 8 of 8
Thread: Seized spark plugs
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Seized spark plugs
    In my work, I deal with small motors, usually 10 to 40 HP air cooled, single, two and four cyclinder, although we also have some water cooled engines similar to car engines. Our shop has noticed and increasing occurrence of spark plugs seizing in aluminium motors, stripping out the threads when removed. Initially this happened predominatly in Kawasaki motors, but has now spread to Kohler and Honda motors. Kawasaki has mentioned it in a tech bulletin, recommending the use of anti seize on plugs. The other manufacturers have yet to comment. I am just putting this up here as my belief is that there has been a change to the alloy that aluminium heads are made from or the construction of spark plugs or something that is causing this issue. I wondered if anyone has noticed this in the motor vehicle trade in aluminium heads? I recommend using a small dab of anti seize on spark plugs anyway as it seems to solve the problems.
  2. The Following 3 Users Say Thank You to 4bye4 For This Useful Post:
    Avo (7th August 2017), mudnut (7th August 2017), threedogs (7th August 2017)
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Definitely use the anti-seize since I found a nearly seized plug in the RB30 head, the first time I changed out the plugs. I ended up buying the right sized tap and cleaned up the thread. It was bloody close to being a helicoil repair.
  5. #3
    3 kawasakis a 5 kholer motors on the farm,i may have to have a look and apply anti sieze...cheers.
  6. #4
    Aug 2014
    Kingsley WA
    15 Post(s)
    If your spark plug comes out about a quarter of a turn then jams, screw it back in until you have a new head or motor ready to go. Usually it comes out that far then grabs the thread an rips everything out. Motors are Kawasaki FH451 and FS481, Kohler CH18 and CH20 and also CH680. Now starting to see it on all sorts of engines with aluminium heads, including Kabota and Kohler Aegis which are watercooled motors.
  7. The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
  8. #5
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Now you tell me!!!! yeh don't get me 2 take them out that's for sure
    Farker is still stuck in there
    P.S: My old man is an ex diesel mechanic and always puts a dab of anti seize on spark plugs when he changes his plugs ( TB4.2 EFI )
  9. #6
    Expert billyj's Avatar
    gordon
    3 Post(s)
    yep always put a little anti seize on the threads when going into alloy heads
    gone to the dark side 2017 vdj 79 dc
  10. #7
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    use the al based anti seize works better then the copper one.
  11. The Following User Says Thank You to garett For This Useful Post:
    PeeBee (8th August 2017)
  12. #8
    Legendary dom14's Avatar
    Somewhere inside Victoria, Australia :)
    38 Post(s)
    I make mine by mixing lithium grease with graphite powder.
    RB30, some 2-3 inch lift auxiliary LPG tanks
    Few more mods on the way
    http://www.worldwildlife.org/species/tiger
    https://www.panthera.org/
    Cheetah Outreach
  13. The Following User Says Thank You to dom14 For This Useful Post:
    GQtdauto (8th August 2017)
