6th August 2017, 05:58 PM
Administrator
6th August 2017 05:58 PM
6th August 2017, 06:04 PM
When you have a solution let me know .
6th August 2017, 06:34 PM
Administrator
GQtdauto
I'm now thinking I'm not sure how a triangle shape would even roll over an arch.
More of a strip that is moulded to angle back would probably be better.
6th August 2017, 06:37 PM
Not sure if you remember seeing it mate but my old 55 from Terry had a rolled steel trapazoid profile welded in both front and rear to strengthen and eliminate this issue from your pic.
In regards covering the voids, fabrication work again whilst doing the guard edges would be the ultimate $$ longevity solution. Expander foam for the voids and steel putty on the inside guard edges for a 45 degree angle drain could work temporarily/dodgy too ?
The Following User Says Thank You to MB For This Useful Post:
6th August 2017, 06:53 PM
Administrator
Thanks mate yeah I want to make sure I can access those bits if required that's all.
If I can't find extrusion like that or if there's no other option I'll just have to drill out the rivets or do new fixings in between the flare fixings for a wide strip of plastic to cover both arch fold and door hinge and headlight area.
The Following User Says Thank You to AB For This Useful Post:
6th August 2017, 10:44 PM
Hmmm yeah a tricky one. . . Just a thought but maybe a GU inner guard might be able to be adapted ? ? Unless there's something that's softer than the OEM plastic and more rigid than rubber that could be moulded ro shape somehow. . . Good luck ☺ . . .
The Following 2 Users Say Thank You to Rossco For This Useful Post:
AB (7th August 2017), MB (7th August 2017)
7th August 2017, 05:46 AM
I think Rossco might be onto something there @AB. Remember that roll of thick sheet plastic we had to install 1200mm deep between a customers Oak tree and site. Root Barrier 1mm HDPE plastic I think it was and would heat gun mold to shape too I reckon.
The Following 2 Users Say Thank You to MB For This Useful Post:
AB (7th August 2017), Rossco (7th August 2017)
7th August 2017, 06:34 AM
#8
MB
. . . and heat gun mold to shape too I reckon.
Ah yes heat gun, now there's a thinker . .
Sent from my SM-T800 using Tapatalk
8th August 2017, 07:43 PM
#9
Administrator
Hmmm... you've got me thinking now how much you could manipulate oem guards with some heat?
