Results 1 to 10 of 11
Thread: Airbag code query
    Expert Daveyboyjunior's Avatar
    Feb 2015
    Dartmoor, England
    Airbag code query
    Had my airbag checked at the dealership today on Recall.
    Patrol went in with continual flashing airbag light (as mentioned here before) i start the vehicle to come home, and its flashing code 22
    (two slow flashes followed by two quick flashes).
    When i questioned the guy about the airbag light flashing a code, he said it would have to be booked in at my cost, to put it through the diagnostics even though he'd told me they had removed one airbag to check it!
    Does anybody know what part of the system code 22 refers to?
    Remove the battery for 1 hour and clear the code and see if it comes back.
    Feb 2015
    Dartmoor, England
    Gotta be worth a go, cheers MR.
    I'll try the other resets to clear the codes if that doesn't work
    Dec 2015
    WA
    5 Post(s)
    Open the drivers door, push the door switch so the car thinks the door is closed, make sure car is in neutral or park, handbrake on, turn on the ignition, do not start, release and press door switch 10 times in 10 seconds. This should clear the codes, if they come back there is a problem.
    Graham
  6. The Following 3 Users Say Thank You to GeeYou8 For This Useful Post:
    Daveyboyjunior (1st March 2016), MudRunnerTD (23rd February 2016), threedogs (23rd February 2016)
    Super Cheap will clear codes, or might be time for either an Ecu-Talk or a Scan gauge
    so you can clear your own
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #6
    Feb 2015
    Dartmoor, England
    Cheers Guys, I would still like to check the 22 code to find out what the problem may be, but the flashing light is a pain.
  10. #7
    Feb 2015
    Dartmoor, England
    Still got the airbag light flashing two slow, two quick, (22) any ideas?
  11. #8
    Feb 2011
    Pretoria, South Africa
    According to the manual it is the left side airbag. It is the airbag in the seat.
    Check under the seat if the connectors are connected.
    Search on youtube for How to reset nissan 350Z airbag and follow the procedure.
    It is how I reset my airbag light a few years ago.(Mine was for the right side airbag).
    The airbag light kept on coming back until I bypassed one of the connectors under the seat. I wired it from the connector in the back of the seat to the first connector under the seat.
  12. The Following User Says Thank You to johanp For This Useful Post:
  13. #9
    Feb 2015
    Dartmoor, England
    Thanks Johan,
    Will check this out. I had noticed the carpet under my seat was wet. I've obviously had water ingress ( I'm investigating that to), but im wondering if the harness or a connector may have been affected by this water enough to raise a code?
  14. #10
    Beginner LuRkIn's Avatar
    Jun 2017
    Sorry for the thread dig i have a 2002 4.8 with the dreded airbag light flasing. Have the same code as op 2 long flashes followed by 2 short flashes (22)? Is it definitely passenger airbag or is thier a page were you can convert the flashes to the fault code? Had a mate put his autel diagnostic tool on but come back as all systems working fine.
