Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Oil leak
    49 Post(s)
    Oil leak
    I finally got around to having a look at where my slight oil leak is coming from. Looks like it's coming from the original oil pressure switch. As per the photo it's dry closest to the engine block however it looks wet where the plug side is, could this be leaking from there.
    I might have also found the culprit to my lowish oil pressure. I took the T out and found a bit of junk stuck in their, blew it out, put it back together, started, oil pressure little better don't really know till I give it a good run.
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Unusual for the actual sender unit to leak but looks to me like that's what is happening .
  4. The Following User Says Thank You to GQtdauto For This Useful Post:
    jay see (4th August 2017)
  5. #3
    49 Post(s)
    Yeah, never seen it before. @mudski any left.
  6. #4
    The master farter
    mudski's Avatar
    461 Post(s)
    Not all that uncommon for the sender unit to leak. The bakelite section goes hard and brittle from the years on engine heat and eventually oil leaks through where it seals in the metal housing.
    I got some switches still mate, but you have a Supershit Auto near by. They will have one.
  7. #5
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Those senders are bloody close to the turbo, and i see yours hasnt got the heat sheild fitted anymore.
    Can see why its failed, cheap easy fix though..
    The master farter
    mudski's Avatar
    461 Post(s)
    No turbo on his donk Kallen. Its a 4.5 petty...
  9. #7
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Augh righto.
    That last pic i saw the heat sheild.and looks similar to my zd.
    But really thats probably worse as the petties run hotter than diesels..
    49 Post(s)
    Yeah picked one up today while was there. Will fit it tomorrow.
  11. The Following User Says Thank You to jay see For This Useful Post:
    mudski (6th August 2017)
  12. #9
    49 Post(s)
    Job done and no more leak.
    Doesn't look like it's done anything for the oil pressure.
  13. #10
    Legendary dom14's Avatar
    Somewhere inside Victoria, Australia :)
    38 Post(s)
    For the oil pressure, it's better not to rely on the stock(or even aftermarket) gauge.
    It's always better to fit an external meter gauge and confirm it. Yours have a T, so I'm guessing there is
    an aftermarket oil pressure gauge fitted. If both stock & aftermarket gauge are showing as low oil pressure, then
    it might have low oil pressure, but I wouldn't try anything big to fix the oil pressure issue,
    until I confirm with an external oil pressure meter.
    Mine has been showing low oil pressure since the beginning of time and the oil pressure suddenly sprung back
    after I took the oil pressure sender out and cleaned it with carby cleaner and pressurized air.
    The tiny hole that the oil goes through to put pressure on the spring mechanism inside the sender unit get
    clogged up with gunk eventually. Instead of buying a new one for $120, I cleaned the old one and put it back, as good
    as new. The other possible issue is the electrical connection/resistance. Sender's body itself is the negative(in mine).
    Lot can happen with a weak earth connection.
    RB30, some 2-3 inch lift auxiliary LPG tanks
    Few more mods on the way
    http://www.worldwildlife.org/species/tiger
    https://www.panthera.org/
    Cheetah Outreach
