1st August 2017, 02:50 PM
4.8 GU engine malfunction indication light on?
Hi,
I have a 04 GU 4.8 Patrol. Have a couple of issues to ask about.
1. the inlet manifold has a butterfly valve assembly inside it. There are 2 bolts that hold it in place on the arm that opens and closes. On my 4x4, the 2 bolts came undone. One went into cyclinder #6 and the other was sitting in #3. There was a bit of damage as the blots got jammed between the valves causing lack of power when driving. Anyway, took it to the workshop and had the top part redone, head, new gaskets, etc. Runs like new.
Should I ask Nissan if they would cover some of the bill?
2. Just this morning the engine warning light MIL came on. I have disconnected the battery to see if it will reset with no luck. I will be taking it back to the workshop tomorrow to get the scan tool on it to see what the issue is.
Any ideas and input is appreciated.
Regards
1st August 2017 02:50 PM
1st August 2017, 03:33 PM
I dont think Nissan will foot any part of the bill on a 13 yr old car.
Its just unfortunate that it's happened. Something i have not heard about happening before.
Maybe someone had it undone previous and never put them back in properly or with threadlocker on. Just a thought.
As for the check engine light as you said get the codes off it and go from there. Could be anything
