Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Pump.
    Jul 2013
    3 Post(s)
    I will reserve you a seat next to the Davesstuff Pavillion where it rains golden snow flakes in between rays of diamond coloured sunshine - see you there my clever friend!!! - I wish it was that easy.
    I`ll be there, when`s it on?
    Jul 2013
    3 Post(s)
    Good idea but flow rate may be a killer.
    I use a Jiggler Siphon (19mm will take about 2 minutes to do 20 litres).
    https://www.google.com.au/search?q=j...w=1178&bih=912
    Great tip I saw somewhere is if you use it for drums/jerries as opposed to vehicle tanks with bends in the fillers.
    Get a bit of semi-rigid hose (like retic) and put it between the valve and the flexible hose.
    That allows you to easily guide the valve to the lowest corner of the drum.
    Had time to kill and needed some thing to do to keep myself amused, as you do.
  4. #13
    Beginner Neville89's Avatar
    Dec 2017
    Thanks for the tip! I'll give it a try next time.
