Results 1 to 9 of 9
Thread: Lift Height on my Patrol
    Beginner denk82's Avatar
    Nov 2017
    SE QLD
    Hi all. Proud new owner of a 2012 GU CRD
    I'm trying to work out how much it has been lifted if any. Starting to make improvements and additions to her and starting off with new wheels and tyres.
    My measurements running 17" stock rims from bottom of rim to wheel guard is 850mm rear and 810mm front. From the centre of the rim it's 580mm front and 620mm rear.
    I haven't been able to find factory heights for the vehicle yet...
    Sent from my Pixel XL using Tapatalk
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Looks like a 2" lift from the photos , there is a stock overall height on a thread here somewhere try the search bar top right side .
  4. The Following User Says Thank You to GQtdauto For This Useful Post:
    denk82 (21st January 2018)
    Nov 2017
    SE QLD
    Cheers thanks for the heads up
    Patrol Guru TimE's Avatar
    Canberra
    Check here for all your Y61 specs via Road Vehicle Descriptor Details
  7. The Following 2 Users Say Thank You to TimE For This Useful Post:
    denk82 (21st January 2018), the evil twin (21st January 2018)
  8. #5
    Nov 2017
    SE QLD
    Quote Originally Posted by TimE View Post
    Thanks mate
  9. #6
    heard somewhere the police measure mudflaps at 300mm to the ground any more theyll bust you.
    Happy to be wrong
  10. #7
    Legendary happygu's Avatar
    Definitely looks like a 2" lift.
    I measured a standard GU Ute on flat ground at a dealer to check against my wagon, and I measured bottom of the rim to wheel arch ( normal way ), and also measured ground to wheel arch. Can't find the bottom of the wheel to wheel arch measurements, but found the ground to wheel arch at 920mm.
    I did it this way also, as that is the way I thought the Police may check as they wouldn't have the other measurements, and would be looking for the overall 75mm change in suspension height limit
  11. The Following User Says Thank You to happygu For This Useful Post:
    denk82 (9th February 2018)
  12. #8
    I always measure from centre of the hub to the wheel arch, takes into account differences in wheel diameter.
    But another vote for looking like a 2in lift
  13. The Following User Says Thank You to Clunk For This Useful Post:
  14. #9
    X2 and X2
    Suspension lift and/or/either Body Lift is measured hub centre to wheel arch
  15. The Following User Says Thank You to the evil twin For This Useful Post:
