2nd August 2017, 11:33 AM
#21
Legendary
AB
Thanks mate, might take you up on that, will your offset bar and your body lift match my spacing or will it give it me a false sense of security lol
The body lift should be fine but spacing may be a little different, just have to do a bit of measuring I reckon.
Interesting enough was looking at bars @ patrolapart and guy was saying that ARB & TJM bars are really similar. Apparently ARB ones fit on the outside of the chassis and TJM go inside the rail, so if that's the case my old one is a TJM and the new one an ARB. . . Kinda like the fitting inside the rail better. .
2nd August 2017 11:33 AM
2nd August 2017, 04:44 PM
#22
Administrator
Nah all good thanks Rossco.
I forgot the issue I had with mine being it was a crazy 900mm long x 85mm thick x 240mm high.
This one sits too wide and goes past each bar support so a 300mm high would not work along with the inlet/outlets on angles.
The one OldMav and most people use being 600x300 with straight outlets inlets works perfect and sits in between the bar supports.
It actually fits pretty snug!
Sold!
The Following User Says Thank You to AB For This Useful Post:
