Results 1 to 7 of 7
Thread: ZD30 Turbo
    Expert clubbyr8's Avatar
    Penrith, NSW
    ZD30 Turbo
    Seems my run of bad luck is continuing. The fourth problem in the last month or so is now car related. I'm getting a nasty grinding noise from the turbo area on my ZD30. Seems to quieten down when it warms up a bit but doesn't go away. Boost seems pretty normal (according to the Torque gauge) but not sure how accurate it is. Power is pretty crappy. Anyone know where I can get it looked at around the Penrith area and how much a replacement would be?
    TIA.
    GROOVY GUVII
    43 Post(s)
    Quote Originally Posted by clubbyr8 View Post
    TIA.
    Check the intake for oil
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    clubbyr8 (26th July 2017)
    175 Post(s)
    G'day mate. How exactly is the noise grindy? Is it louder under boost / load ?
    Just curious whether it could be the cracked EGR pipe behind the motor near the snail. My noise was first diagnosed as a turbo. It almost sounded like it was spooling up with a heap of sand inside it. But in fact it was the harsh air gushing out of the split EGR pipe.
    Thought i'd mention it as it's an easy check and a cheap one to tick of the list.
  6. The Following User Says Thank You to Hodge For This Useful Post:
  7. #4
    581 Post(s)
    As above and check your intercooler and piping too. Our old zd30 had a similar grinding sound on start up but would quiet down after a minute or so.
    Ended up being a crack in the IC, crack closes up a bit when engine heated up and was hard to diagnose.
    Noticed oil residue on side of the intercooler.
  8. The Following User Says Thank You to AB For This Useful Post:
  9. #5
    Penrith, NSW
    Seems it's an exhaust manifold leak....
    GROOVY GUVII
  10. The Following 3 Users Say Thank You to clubbyr8 For This Useful Post:
    AB (26th July 2017), BigRAWesty (26th July 2017), Hodge (26th July 2017)
  11. #6
    43 Post(s)
    If thats it its a good outcome
    175 Post(s)
    It makes sense. It's louder when cold, but gets quieter as metal warms up, expands, closing the gap... Exactly like the EGR pipe on my CRD.
