20th July 2017, 11:15 PM
Td42 conversion...
Gday my fellow Patrol nutters. After blowing up 2 turbos and now damaging my bottom end in my GU ZD30, I have decided to give it a real heart. The issue that I have now is that my TD42 is missing some vital parts. So now I am chasing a TD42 long motor ( not running is ok ) so I can pilfer the parts I need. So who has what and what are you chasing for it.
Thanks in advance
20th July 2017 11:15 PM
20th July 2017, 11:42 PM
Moderator
Hi mate, welcome to the forum. What parts are you looking for off a Long Motor?
Check out my Toy -->
Rogue Dung Beetle
21st July 2017, 08:27 AM
Hey Mudrunnertd, the motor I got has been cannibalized just a bit. I am missing the obvious starter motor, alternator etc which is no big issue but the various nuts and bolts that people have taken off could be hard to work out. (Water pump bolts, brackets and associated nuts and bolts)Also I need an inlet manifold, the gear ring is missing off the injector pump and the nut that holds it on and the cover... etc etc. That us why I'm chasing a blown ling motor. Will be much easier to just take parts from it. I am even missing 1 push rod ? Wtf..
