Results 1 to 7 of 7
Thread: Loss of power in 3rd gear
    Beginner Patrol Girl's Avatar
    Jul 2017
    Queensland
    Question Loss of power in 3rd gear
    Hi,
    I have a 2001 GU ll 3.0ltr Diesel,manual.
    I have just replaced the glow plugs and cleaned the MAF using MAF cleaner and now when driving either up hill or on flat road 3rd gear will not go past 2.5 rev just stays at same out put until I change into fourth gear. All other gears are fine. Any help/advise please.
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Won't be anything to do with glow plugs but possibly the MAF sensor , was it like that before you cleaned the sensor?
    And what did you clean it with ?
  4. The Following User Says Thank You to GQtdauto For This Useful Post:
    Patrol Girl (20th July 2017)
    Legendary happygu's Avatar
    I also think it is the MAF Sensor itself ... they are fairly fragile, and don't like being disturbed too much.
    There are certain voltages it should be outputting. See this thread for voltages http://www.nissanpatrol.com.au/forum...ng-MAF-sensors
    If you have another I would swap it out to check
  6. The Following User Says Thank You to happygu For This Useful Post:
  7. #4
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Delicate little suckers , I cleaned mine with a can of Inox spray lube and $270 bucks later it was working just fine .
  8. The Following User Says Thank You to GQtdauto For This Useful Post:
    happygu (19th July 2017)
  9. #5
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Sorry should have added don't clean the sensor with spray lube of anytype .
  10. #6
    Jul 2017
    Queensland
    Somethings are just better off not being touched haha. So today so far no lack of power in 3rd gear go figure, I am still concerned as something has to be amiss somewhere. So might get a new MAF just in case, check all the hoses are not crimped or loose. I have to put a new Idler pulley joy joy.
  11. #7
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Quote Originally Posted by Patrol Girl View Post
    Having a spare MAF sensor and belt tensioner is just part of owning one of these patrols but the go anywhere nature of them outweighs any negatives .
