Results 1 to 10 of 18
Thread: How to spot the leaking cylinder - old skool way
    Legendary dom14's Avatar
    38 Post(s)
    I found this video is pretty handy.
    This is an old school technique to find out which cylinder is(or which cylinders are) leaking combustion gas into the coolant or alternatively whether combustion gas is leaking into the coolant at all.
    CHECKING A BLOWN HEAD GASKET WITH NO SPECIALIZED TOOLS
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. The Following 2 Users Say Thank You to dom14 For This Useful Post:
    johno90 (23rd July 2017), NissanGQ4.2 (18th July 2017)
    38 Post(s)
    And this, which gives a list of tests that can be done for testing a blown head gasket/cracked head.
    HOW TO CHECK FOR A BLOWN HEAD GASKET
    Cheetah Outreach
  5. The Following User Says Thank You to dom14 For This Useful Post:
    mudnut (13th November 2017)
  6. #3
    Expert johno90's Avatar
    Moranbah QLD
    Not really old school, its pretty common first step check ups only pull the tools out when its not an obvious thing, as in porous metals and fine cracks.
  7. The Following User Says Thank You to johno90 For This Useful Post:
    dom14 (23rd July 2017)
  8. #4
    38 Post(s)
    Quote Originally Posted by johno90 View Post
    Yeah, I actually modified the test by attaching a bottle to the radiator and filling it with coolant/water so I can see the escaping air bubbles clearly and the volume of air bubbles.
    I like OldSkool Funk's approach of taking all the spark plugs out and then putting one spark plug at a time while cranking.
    Pretty basic, but didn't pop into my head the simplicity and effectiveness of the test.
    Cheetah Outreach
  9. #5
    Nov 2017
    caboolture
    Thanks for the video links mate good work
  10. The Following User Says Thank You to jsawrey For This Useful Post:
    dom14 (11th November 2017)
  11. #6
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    good Vid @dom14
    now I feel old school - as thats how I was taught to diagnose a blown head gasket
    hahahahahaha
  12. The Following User Says Thank You to Bigcol For This Useful Post:
  13. #7
    49 Post(s)
    I can't get the link to work.....
  14. The Following User Says Thank You to jay see For This Useful Post:
    dom14 (12th November 2017)
  15. #8
    38 Post(s)
    Quote Originally Posted by Bigcol View Post
    good Vid @dom14
    hahahahahaha
    Yeah, it's good to know these methods. Kids' these days can't add two numbers together without a calculator.
    We did all in our heads.
    Cheetah Outreach
  16. #9
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    yeppers
  17. The Following User Says Thank You to Bigcol For This Useful Post:
  18. #10
    38 Post(s)
    @jay see. John, sorry for the late reply mate. Links are working fine from my end. I reckon it might have something to do with your smartphone, assuming you're using the phone!? Let me know.
    Dom
    Cheetah Outreach
