16th July 2017, 01:11 PM
Legendary
Removing Carbon From Piston, Cylinder Walls, and Block Deck
I found below video is pretty useful as a guide for the above jobs.
The Following User Says Thank You to dom14 For This Useful Post:
16th July 2017 01:11 PM
16th July 2017, 01:24 PM
I find it interesting that some "old-school" mechanics would leave the carbon build-up as it improved the compression. Taking into account that I am by no means a learned person, this is the first time I've heard that a hot spot can occur due to the build up. The WD4O does a great job at removing most of the carbon, though.
16th July 2017, 02:16 PM
Patrol Freak
subaru upper engine clean.
16th July 2017, 02:28 PM
Legendary
mudnut
Yeah, they do, and that is the case with excessive compression in mine(I bet even though I haven't pulled the head yet to see).
The problem is that it makes it an absolute PITA with the tuning of the engine, both carby wise & ignition timing wise, 'cos of the hot spots.
So, I don't think it is beneficial overall to have shyte loads of carbon buildup. A little bit, may be.
Particularly the thick layer of carbon build up on the piston crown is a real PITA with engine performance, and better have it scraped off.
16th July 2017, 02:31 PM
Legendary
garett
Bloody expensive though. I used plain water instead.
I bet there is a backyard chemical alternative that we can add to water. (speculating stuff like detergent, vinegar, etc, )
Water definitely cleans the spark plug soot buildup & bit of piston crown soot buildup.
How about Seaform stuff?!!
https://www.youtube.com/watch?v=agAWXnT4-EQ
16th July 2017, 02:33 PM
Legendary
Do you guys know a local retailer(either online or shopfront) that sells below bristle discs??!!
http://www.ebay.com.au/itm/3M-Roloc-...BS-fVh_RyCKLcQ
https://www.youtube.com/watch?v=zoEh3sq_s1U
I have the damn air tool, but can't locate the bristle discs.
16th July 2017, 04:02 PM
Patrol Freak
you could spend 3 days cleaning or just spray it with the suby cleaner wait 10 min then wipe it off.
16th July 2017, 10:19 PM
Legendary
17th July 2017, 05:51 AM
Patrol Freak
dom14
it's should be about 20-30 bucks a can..
The Following User Says Thank You to garett For This Useful Post:
