Results 1 to 3 of 3
Thread: Td42 turbo
    Nov 2016
    Td42 turbo
    Hey guys I'm about to buy a 16g mamba turbo it comes with oil lines and I will order a manifold. just curious about where the oil lines go and where to get a crossover pipe from 😉
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    I'd advise buying the 16G with the 6cm bolt-on turbine housing so you can bolt a 3" dump directly to it. That pic is showing the clamp for the V-band turbine outlet.
    If you're fitting it to a N/A engine, the oil pressure outlet is a grub screw just above the LH engine mount. Have a search, there are tons of pics around showing the grub screw.
    John
    581 Post(s)
    Spray that oil feed bung for weeks prior to removal.
    It's easy to jam up and strip the head, very easy!
