Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Injector pump DIY rebuild info needed
    Expert Deano2506's Avatar
    Apr 2017
    Hobart,tasmania
    Gday mate.
    Yep hobarts really expensive...there's only 1 diesel shop here so he can charge what he wants.
    Does great work though
  2. The Following User Says Thank You to Deano2506 For This Useful Post:
    GQtdauto (5th July 2017)
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Still sussing it all out and learning a bit about the pump , never knew rotating it was similar to rotating a dizzy to change the timing .
    First I need to work out exactly what type of pump it is although it's supposed to be a 10 mm Zexal , plenty of good info and how to vids and info out there .
  5. #13
    North brissy
    Now that explains it , I was thinking no way can you get an impact driver on three of those screws without removing the manifold thanks for the tip .
    One question though , won't I have to undo the injector lines to rotate the pump .
    You dont have to but it will make it easier. You can get to all of them with an open end 17mm spanner anyway.
    Dont forget the bolt on the bottom support bracket.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
  7. #14
    North brissy
    Yep kind of. Changes the point of beginning of injection.
  8. The Following User Says Thank You to nissannewby For This Useful Post:
