Results 1 to 5 of 5
Thread: Springs not seated properly ?
    Jun 2017
    Hi all, I recently picked up an immaculate Maverick TB42. First thing I did was install 2" coil spacers front and rear. Fast forward 2 weeks and I was under the car yesterday and noticed the rear springs seem to be stretching the poly spacer towards the rear. I removed the factory rubber spring seat/isolater from on top of the coil before installing the poly spacer. Have I done something wrong here, or have I just seated the top of the springs too far forward ?
    Legendary
    194 Post(s)
    Quote Originally Posted by 91Mavman View Post
    Photo would help!
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    I found that it took a few goes to seat the springs properly. It can be done by one person but I found it best if you have a couple of people to hold the springs in as the jack is slowly raised.
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    I discovered some brands of the large spacers have quite a flat spring seating surface, and don't seem to have much (or any) locating lip or groove to help locate/retain the spring in position, the poly spacers are very firm and also provide very little friction, so springs can slide around a lot.
    Check to see if this is the case, as may need to try a different brand ?
    <a href=http://i83.photobucket.com/albums/j320/02ard/PatrolcomAvatar-1-1.jpg target=_blank>http://i83.photobucket.com/albums/j3...Avatar-1-1.jpg</a>
  6. #5
    Jun 2017
    Thanks for responses guys. Turned out to be the rear spacers weren't the right ones for this model. Ebay seller is posting the right ones to me so all should be sweet.
  7. The Following 2 Users Say Thank You to 91Mavman For This Useful Post:
    04OFF (7th July 2017), MudRunnerTD (7th July 2017)
