Results 1 to 10 of 57
Thread: DIY -Ryco A360 flat panel airbox with 4" in/out
Threaded View
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    I've just made my own flat panel airbox with 4" in/out and thought it might interest some of you.
    For space reasons I chose the Ryco A360 air filter. This is standard on some old VN & VS Commodores and also the GQ TB42E and some Nissan Skylines.
    I got a 600 x 600 x 1.6mm sheet of mild steel from Bunnings and a couple of 4" mandrel bends from Ebay but only used cuts from the 45 degree.
    I can't weld aluminium so I'm making it all in mild steel and welding with a MIG.
    Made a mockup from card board.
    Drew it on the steel plate and plasma cut it with my little Ebay cutter.
    Bent it into shape.
    Then I made the lid. The shape was decided by the height to fit under bonnet and the A/C & steering hoses.
    Welded on the outlet pipe and did some trial positioning.
    I then welded a 15x3mm skirt around the lid that serves as the lip that tightens down onto the filter edge.
    Welded some fixing tabs and painted it all ready to go.
    All bolted in.
    Cost came out under $200 including steel, A360 element and silicone hoses & clips
    I still need to cut a bigger opening in the inner guard to have a 4" elbow coming through.
    I plan to retain the current Nissan snorkel.
    John
  2. The Following 12 Users Say Thank You to jff45 For This Useful Post:
    Bloodyaussie (17th February 2016), clubbyr8 (19th February 2016), Clunk (17th February 2016), gaddy (17th February 2016), Hodge (17th February 2016), jay see (17th February 2016), MudRunnerTD (17th February 2016), mudski (17th February 2016), NissanGQ4.2 (6th April 2016), SiberianPatrol (17th February 2016), Sprock (18th February 2016), threedogs (17th February 2016)
