13th June 2017, 11:46 PM
Bang went the egr pipe
So the Troll started to sound like an old tractor after a slight bang about 5 houses from home, no power loss just a noisy exhaust sound. Turns out I blew the end off the EGR connection pipe at the manifold end. Question is am I able to get it re welded or do I need to buy another one? Or do I just block off both ends and Daws it?
NED The Iron Outlaw, 2006 GU Manual ZD30Di.
13th June 2017 11:46 PM
14th June 2017, 12:31 PM
Save your self the trouble and just get another one
but try and find why it blew apart
14th June 2017, 06:51 PM
Same thing happened to our work navara. Yep went bang pretty good then was loud as buggery it was pretty slow without boost that was 4 sure, nursed it back to the yard tho . .
15th June 2017, 01:05 PM
I would block both ends and just put the bust pipe back on. Just so it looks like its there and working incase the fuzz have a look. As to why it did it, its not uncommon for it to go, not that common either lol, but its usually just a fatigue break. Due to heat and vibration. The CRD's do this more than the Di's.
15th June 2017, 01:07 PM
long time since I last heard that expression. I approve.
The Following User Says Thank You to 4bye4 For This Useful Post:
