9th June 2017, 05:00 PM
Will a GQ front LOKKA fit in my new 04 GU?
Hi,
Anyone knows if a GQ front LOKKA fit in my new 04 GU?
Or can i just swap the whole front axel? Or is the Gu axel/brakes etc better?
Thx
9th June 2017 05:00 PM
9th June 2017, 05:18 PM
Moderator
Yes it will go straight in. If the Diff Ratios are the same then you can just swap the whole centre, if they are different the Lokka will go straight into the GU Centre.
The GU Diff is a far better assembly than a GQ with bigger CVs and bigger Brakes and Wider to suit the GU Body.
Check out my Toy -->
Rogue Dung Beetle
12th June 2017, 01:27 PM
MudRunnerTD
Thx that helps a lot
12th June 2017, 06:45 PM
SPAMINATOR
MudRunnerTD
What he said ^^^^
