Results 1 to 3 of 3
Thread: Td 4.2 conversion
    Advanced morton2478's Avatar
    Mar 2015
    Td 4.2 conversion
    I am just wondering how people in nsw have gone with doing the conversion from the 3ltr to a 4.2 my question is do you need to get it engineered i have had some people say no just needs blue slip and then others say it has to be engineered. I am assuming that it would need engineering due to changing the engine mount position to suite the td4.2 . Thanks Dave
    Sent from my SM-T530 using Tapatalk
    462 Post(s)
    Dave not sure in NSW but here in Vic, all Vic Roads care about is, if the vehicle came out with the planned motor to change, as a factory option then no engineering is required. Even though the mounts need to be welded on they didn't care about this in my case. But I'm thinking they don't know about this requirement to actually do the change, I just had to supply proof that the TD was a factory option. Which I did with a copy of the original advertising pamphlet which showed all the options. Kindly supplied by Nissan's head office with one phone call. In the end I did get my Patrol engineered though. Well it went in to get the 4inch lift engied, but they said they must do the entire vehicle, so it did.
    The vic roads website actually stated the info about the motor change, so your RTA office, or whoever they are called, should do to I think.
    Mar 2015
    Thanks mark i hope it's the same up here i would like to hold off on the engineering until i finsh a few other jobs and get it all done together
