6th June 2017, 09:50 AM
#11
Thanks for all the info people, much appreciated.
Last night I remembered I ran a set of Hercules on my Navara and they were darn good. They use a Cooper carcass and their own tread rubber, so they have a good tough carcass on 'em.
Nitto & Kenda have also been mentioned to me as well.
6th June 2017 09:50 AM
6th June 2017, 11:18 AM
#12
I had a set of feds in a 35x12.5R15 and they weren't too bad. Now running Couragia cf3000's and I find them much better in the mud. Probably a bit worse on wet bitumen but only slightly. cf3000's are quieter than the feds were, throw better, seem to handle dry roads better, have been very happy with them so far.
6th June 2017, 11:27 AM
#13
Throbbinhood
How many K's have you done on them??
6th June 2017, 01:08 PM
#14
You can swap for my 285 x 16 federal Muddies if you want just on 50%
6th June 2017, 01:23 PM
#15
10G
I reckon I did around 10-15k km's on the Feds. They were probably around 75-80% tready at that, so would've expected to get to 40-50k which for a cheap tyre I'm more than happy with.
The Comforsor's, I'm probably up to about 3k km's. Wearing well so far. I don't daily this car so the kms come on slowly and usually involve a lot of offroad.
6th June 2017, 01:58 PM
#16
threedogs
Thanks TD, but nah. A muddie at 50% is called an AT ;-)
14th August 2017, 01:15 PM
#17
I had a bad experience with Federal Couragia's. Apart from being noisey, uncomfortable and wearing fast, I was inspecting them one day and found one had started to split right down the middle. The rubber was actually splitting between the tread blocks and you could see the canvass. Took it back and the shop said they'd never seen that happen before. They replaced it FOC but still not very inspiring. Also had one suddenly lose all it's air while driving on the highway (unsure of the cause). I wouldn't trust them, particularly not in any terrain where you actually need a mud tyre. Speaking from experience only.
14th August 2017, 03:16 PM
#18
Has anyone dealt with this mob? $245 for a new KM 2 seems cheap. https://www.gumtree.com.au/s-ad/suns...km2/1147040709
14th August 2017, 07:57 PM
#19
275 fitted and balanced though. Having a quick look on the net that is in the bal park for them fitted and balanced.
The Following User Says Thank You to nissannewby For This Useful Post:
mudnut (14th August 2017)
14th August 2017, 09:00 PM
#20
Patrol Guru
I run 33" Kumho MT51s , about $300 a tyre fitted , awesome in mud & wet grass etc , did heaps of full on mud tracks in 2WD ( to prove a point ) that my mates struggled in 4WD.
