Results 1 to 7 of 7
Thread: Power steering oil change?
    Legendary dom14's Avatar
    38 Post(s)
    Hey Guys,
    Do I need to replace the power steering oil completely once every couple of years or so?!!
    I haven't done mine for years. All I do is topping up the oil once every six months or so.
    Thanx
    Dom
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    38 Post(s)
    This is a good video demonstrating how to flush the power steering fluid.
    I'm gonna go ahead and flush the oil.
    https://www.youtube.com/watch?v=Iev1xIr345Y
    https://www.youtube.com/watch?v=A0fiZCHz5ew
    Cheetah Outreach
    38 Post(s)
    And this is a video demonstrating how to do a "super flush"
    https://www.youtube.com/watch?v=1F4MzsTyFMo
    Cheetah Outreach
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    if it smells burnt or looks dirty i'd change it
    if your topping it you might like to try Lucas Oil Power Steering Stop Leak i've used it and can confirm it works well for small leaks been in the wifes car for 2 years and no sign of any more leaks.
  6. The Following User Says Thank You to garett For This Useful Post:
    dom14 (4th June 2017)
    38 Post(s)
    Quote Originally Posted by garett View Post
    Yeah, it smells kinda burnt. Looks burnt as well.
    I'll be flushing it completely today, and then thiking adding above stop leak with some conditioning additive as well.
    I just have to wait until Repco or Autobarn opens to buy them.
    Thanx.
    Cheetah Outreach
    22 Post(s)
    Thanx.
    If the oil is burnt, something is burning it. If the pump is screeching and carrying on aswell, there is an issue. Possibly a shagged bearing over heating the oil and causing cavitation. If this is the case, fresh oil is a bandaid fix and additives will do bugger all. The only fix is rebuild or replace the pump.
    96 GQ coil/Cab
    08 G6eT
  9. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    dom14 (4th June 2017), mudnut (5th June 2017)
  10. #7
    38 Post(s)
    I checked the bearing. It looks and feels ok. No dragging, noise or play.
    I'm thinking pump internals are partly screwed from running ancient oil for too long.
    I'll be rebuilding it soon & then I'll put synthetic oil, so to not having to bother changing power steering oil for the last half of the vehicle lifespan.
    Cheetah Outreach
