7th June 2017, 09:27 PM
ZD30 - Hose dropping oil onto front axel - newbie Q
Hi Guys, first post so I hope i haven't done anything incorrectly.
This is probably (and hopefully) a dumb question. I have noticed a bit of sticky oil drops on the floor of the garage after my latest two outings in the ZD30 (This car is new to me, only driven a few times so still getting my head around stuff). Tonight i managed to get a quick look underneath and found quite a bit of oil or similar on the front axel and believe it could be coming from what looks to be a breather hose positioned above. I'm not 100% if this is normal, alarming or even a breather / overflow hose at all.
In the middle of the image below is the hose, which does appear to be the culprit.
Could somebody shed some light on if this is a lose hose / normal operation?
Thanks in advance
7th June 2017 09:27 PM
7th June 2017, 09:31 PM
It looks like the drain hose off the oil filter drip tray.
The oil filter is a cartridge type, with a re-usable metal housing, so it is impossible not to spill oil on an oil change
7th June 2017, 09:56 PM
Thanks for that happygu The filter was replaced a few weeks back so I guess that makes sense.
8th June 2017, 12:17 AM
SkippyGU
If you want to give it a quick degrease and a drive around then jump under it and see if you can see where it is coming from
Currently own a ZD30 2000 GU patrol with a dead injector pump
about to start a build on a TD42 motor to go in the car and basically rebuild the whole car into a machine of a rig
8th June 2017, 09:18 AM
go change the oil filter and change the O ring at the same time.
some ppl are slack and will not change the O ring, just lazy if you ask me
Also these ZD30 motors dont like being overfilled so keep oil level just under the full line
8th June 2017, 03:07 PM
after you have changed the new filter and "O" ring take it down the car wash
and give it a decent clean, Be a bit wary water under that much pressure will
get in everywhere, use caution eh
