Results 1 to 3 of 3
Thread: Odometer Overclocking / Cluster Part Failure
    May 2017
    Reposting (had initially posted as an introduction by mistake)
    Hi all,
    I hope you are well. I am based in Nairobi, Kenya, recently bought a second hand Nissan Patrol 2004 TB45 (4.5 Liter Petrol). The odometer is overclocking, for example, 5km for every 1km travelled. I took it to my local mechanic who have diagnosed a cluster fail and quoted USD 2000 for a new cluster. Though from my google searches I can see this is quite a common problem / defect for Nissan Patrols with lots of different options out there to fix, from earthing, to correcting voltage sparks / fluctuations. I am not a mechanic or mechanically savvy enough to do these.
    Basically wanted to check if anyone has had a similar problem and if there is a temporary or permanent fix to the issue? My concern is spending money on a new cluster and then the problem still continuing.
    Thank you!
    Mowgli
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Does the spedometer show the correct speed or is that incorrect as well? Not sure how a 2004 mod works but if both the speed and k's travelled are out I would think the sender end of things ie. gearbox. If only the distance is wrong, I guess the cluster somehow "calculates" the distance from the speedometer, either mechanicaly or electronically. Small descrepancies somtimes occur because of wrong gear ratios, wrong diffs or different size wheels, but 5:1 is hugh.
    461 Post(s)
    Quote Originally Posted by 4bye4 View Post
    Yeah the first thing I'd check is the speedo gear tooth count. You can PM me your VIN and I can see what it should be and then you simply remove the sender unit from the box, one bolt, and see if the gear is what its supposed to be.
